timing. 305 77 camaro
Old Sep 11, 2010 | 04:58 AM
Jaykob's Avatar
Exclamation timing. 305 77 camaro
First off thank you to everyone who helped me with the flooding issue. Now i have another problem. My distributor cap had a post break so i got another one and replaced it. I manually cranked my engine to top dead center (runs at 8 degrees BTDC). Took a long screw driver and turned oil pump so rotor would line up on post on new cap. Now i can't seem to get the dang engine timed again. But it does turn over and run for about a second and a half. If you got any suggestions for setting the timing feel free to tell me. Any knowledge is more than mine. This is also my daily driver, so it is extremely important to have this thing running sunday night. Thanks again!
Old Sep 11, 2010 | 07:23 PM
Y2K's Avatar
Y2K
Why did you pull the dizzy just to change a cap?
Anyway,TDC on what cylinder? #1? and if so are you sure it was compression stroke?
Are you sure you haven't crossed any wires?wish I had a dollar for every time I'd sworn I had them all in the right place and didn't lol.
Old Sep 11, 2010 | 11:05 PM
1976camaro's Avatar
it also might not be ur timming chain your carb could not be tuned...u said it turns over and runs right make sure ur carb is tune fully
Old Sep 12, 2010 | 03:45 AM
Jaykob's Avatar
wires are all in right spot. carb is tuned. top dead on #1. and as far as compression goes it looks like neither the intake or exhaust valve is open when im doing it. unless the difference is minimal in position so i can hardly notice it. but i will keep trying it. and to answer your question y2k, i dont know. i really messed up when i pulled it. ive kicked myself in the butt for doing it.
Old Sep 12, 2010 | 03:57 AM
1976camaro's Avatar
i have a question for you u have a 77 305 right well i got a 76 305 is ur timing chain and gear set a single or a double roller i need to replace my gears and chain i was driving to washington from california and when i stop the car died and i took it apart today and found that the gears are broken
Old Sep 12, 2010 | 06:08 PM
Jaykob's Avatar
i dont understand what you mean by single or double. i know i have 2 sprockets, 1 for the cam and the other for the crankshaft. thats all i got for you.
warmeck
Sep 12, 2014 01:31 PM
Derek Tackett
Aug 13, 2014 10:43 AM
barry3.4
Dec 13, 2013 10:33 AM
ScottD
Mar 18, 2010 12:36 AM
z28 killer
Dec 27, 2008 11:37 PM
