Removing Valve Springs
hey guys, i found this pic of a homade valve spring remover, am i safe to use something like this or does anyone have a better way to get them off cheap? maybe if someone can post a pic of another homade tool?
thanks
joe
thanks
joe
Are the heads off the engine? No reason why that wouldn't work either way. I usually remove the valves by supporting the valve underneath, hold a deep well socket of the right size over the spring cap, give it a quick rap with a hammer, and the keepers would pop out.
Yeah, and try to hit the socket, not your hand! Put a block of wood under the valve you're working on to hold it up.
