Picked up a 350 to swap my 305
Old Jan 16, 2012 | 09:46 PM
  #21
mike6208's Avatar
nice looking carb, alittle much for my budget tho, ill have to search summit racing or pick up a used one for alittle less. but ill def look into it, thanks for the info
Originally Posted by Gorn
I am a little late to the game but if you can swing it take a look at the Holley avenger. I played with holleys for years on race and street cars. Holley advertise their Avenger as bolt on and go so I gave it a try. It worked great right out of the box. I have never adjusted anything on it. I don't push my 67 very hard but it drives nice and friendly at the low RPMs. I might tweak it someday but I don't think I could get it much better without a Dyno.
Holley 0-81570 570cfm Street Avenger Carb JEGS | eBay
Old Jan 26, 2012 | 09:43 PM
  #22
mike6208's Avatar
Originally Posted by rydeer
After 34 years I doubt that the charcoal stuff still absorbs. You can delete it, but then you have a line from the gas tank to nowhere.. You also have an empty spot in the fender nose area.
bringing back this post for min, i took the canister out, but as you said i have the return line going back to the tank, what can i do with that? is it safe to just cap it off, dont want my car going boom!
Old Jan 27, 2012 | 08:27 AM
  #23
Yes you can use a 3/8 bolt in the end of the hose and a clamp around it, or get fancy and remove the hose back to hard line and get a cap for the end of the line.
Summit has a pretty reasonably priced carb also, and a couple friends have them and like them a lot. Only offered in a 600cfm, and $235:
Summit Racing SUM-M08600VS - Summit Racing Street & Strip® Carburetors - Overview - SummitRacing.com
Old Jan 27, 2012 | 11:54 AM
  #24
I don't know what your car has, but make sure you have a vented gas cap if you go corking off the canister vent return line. Previous non-canistered models (like mine) have a vented gas cap (vents in only, not out). If it's not vented, the inside of the tank will become a vacuum and gas will eventually stop flowing.
Old Feb 2, 2012 | 07:57 PM
  #25
mike6208's Avatar
anyone have any insight on the Edelbrock carbs? good no good? found a Edelbrock 1406 locally for a decent price
Edelbrock 1406 Edelbrock Performer Carburetors
Old Feb 3, 2012 | 11:05 AM
  #26
5time F's Avatar
I LOVE THEM!!!!!!!!! Just saying...
Old Feb 3, 2012 | 11:54 AM
  #27
I'm not a fan. Haven't had good performance with the one's I've had, but that was only two of them and I gave up. Holley for my vehicles.
Old Feb 3, 2012 | 12:01 PM
  #28
mike6208's Avatar
scrap the Edelbrock idea , actually just picked up a Quadrajet for 45 bucks, came off a running 350, before i picked it up guy said it was an electric choke, when i got there i see the heat riser setup, grabbed it anyway. should i keep the hot air choke or convert it to electric if even possible?
Old Feb 3, 2012 | 12:06 PM
  #29
Looks like the intake has the heat port for that setup, so I'd keep it as is if you can get the little sheetmetal part to enclose/attach it to the intake.
  #30
If you want to, converting your choke to electric is easy. You just have to remove the existing wind-up coil (the round black thing), and replace with an electric unit.
