Picked up a 350 to swap my 305
Old Jan 15, 2012 | 11:59 PM
mike6208's Avatar
still cleaning up the 350, taking some stuff off the 305 getting ready to pull it out.
question is, can the vapor charcoal canister be removed from the car and not be used when i put the 350 in? whats its main purpose?
Old Jan 16, 2012 | 05:09 AM
rydeer's Avatar
It collects the gas that evaporates in the tank. Just keeps HCs from floating into the atmosphere.It doesn't affect performance in any way.
Old Jan 16, 2012 | 05:48 AM
5time F's Avatar
It does more good then any other part on your car... It traps fumes from your fuel system and only returns them to the motor once it returns to full operating temp."
Old Jan 16, 2012 | 11:59 AM
I'm pretty sure tha canister returns vapors to the tank which then returns to the engine. My '71 had one because it was a Ca. car when new, but not required anywhere else in 1971, so I took the can and return lines out when I bought it.
Old Jan 16, 2012 | 03:15 PM
mike6208's Avatar
im trying to clean up the engine bay alittle, may take mine out, not sure yet.
Old Jan 16, 2012 | 03:53 PM
rydeer's Avatar
If it is still connected to the carb on one end you will have to plug up the port it came from.
Old Jan 16, 2012 | 06:49 PM
5time F's Avatar
Some of them connect to the temp controlled vacuum switched on the thermostat housing. It keeps. It from venting raw fumes into the area around your car. It traps the fumes. So when you start your car it does not go boom.
Old Jan 16, 2012 | 07:25 PM
rydeer's Avatar
Boom is bad!!!! LOL
Old Jan 16, 2012 | 07:29 PM
rydeer's Avatar
After 34 years I doubt that the charcoal stuff still absorbs. You can delete it, but then you have a line from the gas tank to nowhere.. You also have an empty spot in the fender nose area.
Old Jan 16, 2012 | 07:50 PM
  #20
I am a little late to the game but if you can swing it take a look at the Holley avenger. I played with holleys for years on race and street cars. Holley advertise their Avenger as bolt on and go so I gave it a try. It worked great right out of the box. I have never adjusted anything on it. I don't push my 67 very hard but it drives nice and friendly at the low RPMs. I might tweak it someday but I don't think I could get it much better without a Dyno.
Holley 0-81570 570cfm Street Avenger Carb JEGS | eBay
