Picked up a 350 to swap my 305
still cleaning up the 350, taking some stuff off the 305 getting ready to pull it out.
question is, can the vapor charcoal canister be removed from the car and not be used when i put the 350 in? whats its main purpose?
I'm pretty sure tha canister returns vapors to the tank which then returns to the engine. My '71 had one because it was a Ca. car when new, but not required anywhere else in 1971, so I took the can and return lines out when I bought it.
Some of them connect to the temp controlled vacuum switched on the thermostat housing. It keeps. It from venting raw fumes into the area around your car. It traps the fumes. So when you start your car it does not go boom.
#20
I am a little late to the game but if you can swing it take a look at the Holley avenger. I played with holleys for years on race and street cars. Holley advertise their Avenger as bolt on and go so I gave it a try. It worked great right out of the box. I have never adjusted anything on it. I don't push my 67 very hard but it drives nice and friendly at the low RPMs. I might tweak it someday but I don't think I could get it much better without a Dyno.
Holley 0-81570 570cfm Street Avenger Carb JEGS | eBay
