Oval vs rectangular ports for heads
Old Jan 14, 2011 | 03:25 PM
Gen2-454's Avatar
Default Oval vs rectangular ports for heads
Pro's and cons of each cause i have heard different that one is better or the other is better and blah blah...
Old Jan 14, 2011 | 09:07 PM
Depends what you want to use them for. In general, oval port heads are better suited for street use, and rectangular port heads are better suited for all out power. Also, a lot depends on the cam, compression, and head mods such as porting, etc..
Old Jan 15, 2011 | 12:04 AM
Gen2-454's Avatar
im shooting for 9.5:1 comp and im going to use the ***** thumper cam from comp cams
Old Jan 15, 2011 | 11:47 AM
Looking at your compression it would seem that you are building for street use, so as I said before, the oval ports would be the best choice.
Old Jan 17, 2011 | 12:22 AM
Gen2-454's Avatar
The reason im also going for low compression is later on im going to put a blower on it
I'm gonna go for rectangular and awaken the big block beast
Old Jan 17, 2011 | 01:01 AM
The way I see it, you have a couple of options; build a blower motor from the beginning, or build what you're talking about now, then tear it apart to rebuild it for a blower application. 9.5 c.r. is not low, it's still too high for a blower, you need it to be in the 8:1 range. You also want to use forged "blower" pistons that have stronger designed ring lands. Plus if you build a blower motor, but keep it n/a, the low c.r. is going to require you to run a cam with less duration than you would with a blower, or it will be a real dog. Both of these engines would be built totally different from each other. Wanting to build a good streetable engine now, and slap a blower on it later, doesn't work.
Old Jan 17, 2011 | 03:47 AM
Gen2-454's Avatar
I know i was looking at everything and thought Ohhhhhh, this project is going to be a high hp streetable car, my next project will be a 70's trans, that will be the blower motor. I still like the 9.5:1 compression, for the camaro that is. Ill go 8:1 for the trans
mikes68
Jan 9, 2012 11:15 PM
User Name
Feb 8, 2010 10:18 PM
User Name
Feb 7, 2010 06:48 AM
furiousyellow
67-69 V8 Tech
Oct 15, 2008 02:36 PM
American Muscle 100
Sep 12, 2006 12:32 AM
