Oval vs rectangular ports for heads
Pro's and cons of each cause i have heard different that one is better or the other is better and blah blah...
Depends what you want to use them for. In general, oval port heads are better suited for street use, and rectangular port heads are better suited for all out power. Also, a lot depends on the cam, compression, and head mods such as porting, etc..
im shooting for 9.5:1 comp and im going to use the mutha thumper cam from comp cams
Looking at your compression it would seem that you are building for street use, so as I said before, the oval ports would be the best choice.
The reason im also going for low compression is later on im going to put a blower on it
I'm gonna go for rectangular and awaken the big block beast :D |
Originally Posted by Gen2-454
(Post 498760)
I know i was looking at everything and thought Ohhhhhh, this project is going to be a high hp streetable car, my next project will be a 70's trans, that will be the blower motor. I still like the 9.5:1 compression, for the camaro that is. Ill go 8:1 for the trans
