fuel pump
Old Mar 1, 2008 | 06:37 PM
heavyhitta's Avatar
Default fuel pump
my 1980 z28 choked and died on the ay home today,when i tried to start her ,she just trieds and died. i have a clear gas filter so that i can see my gas and it usually remains full for a good while after i have turn the car off,so when i tried to start it again i looked at the gas filter and i could see gas trying to get to the carb but did not seem to have enough pressure, is this my fuel pump? by the way 350/350.
[/align]
Old Mar 3, 2008 | 08:24 PM
dodge destroyer's Avatar
Default RE: fuel pump
The best thing i could tell you to do is a pressure test and see how many psi its at. i believe its should be above 8 or 9 psi but i could be wrong.
Old Mar 5, 2008 | 02:16 PM
73camaroSS's Avatar
pull the filter off and have a budy turn the key if gas doesnt shot out probily the pump but if it does you have a problem some were else, check to see if you are getting spark
[/align]
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
