can i put a 4.77 positraction rear end in my 75 camaro?
Old Jun 19, 2010 | 12:09 AM
tojery's Avatar
Default can i put a 4.77 positraction rear end in my 75 camaro?
can i put a 4.77 positraction rear end in my 75 camaro? i have the original peg leg now and need a new axle for it so i figured i would just upgrade instead and have a great deal on buying this 4.77. im putting a 383 stroker in also so i need the extra power from the rear end.
Old Jun 19, 2010 | 01:26 PM
tojery's Avatar
the rear end is out of a 1980 cutlass g body so idk if it will fit. any advice?
Old Jun 29, 2010 | 07:08 PM
OneShoe50's Avatar
I'd get a tape measure and go to checking. I had a `71 Nova I put a `69 Camaro rear end in, just took the time to double check spring perches and width and it worked ok.
4.77 gear, I've heard of a 4.56 and a 4.86, but never a 4.77. are you able to inspect the gears before you install?
Old Jul 1, 2010 | 10:12 PM
Sounds way too low geared for a 383 stroker. That thing will be screaming at 55 or 60 mph! That's hard on an engine, even for an occasional driver.
My85Camaro
Mar 21, 2011 08:07 AM
Danthemanz28
Apr 20, 2009 04:24 PM
BillB
Jan 21, 2007 07:09 PM
adamGD
May 13, 2006 12:50 PM
