1974 Camaro with 1980 Trans Am Rear End
Old Feb 17, 2011 | 05:40 PM
chicows18's Avatar
Default 1974 Camaro with 1980 Trans Am Rear End
I got a 1974 camaro and we put in a 1980 trans am rear end which has disc brakes. The problem that I have now is that the parking brake cables now do not reach. Can someone tell me what to use to make this work?
Old Feb 17, 2011 | 05:54 PM
Which cables are you trying to use, your original ones, or the ones from the T/A rearend?
Old Feb 18, 2011 | 08:19 AM
chicows18's Avatar
I only have the trans am cables which are the ones im using. I already threw away the other rear end as well as the cables because I didnt think i would use them plus I didnt think they would work since those where drum brakes and this one is disc brakes.
Old Feb 18, 2011 | 09:14 AM
Can you take a picture of the brake cables as they are now? Might be able to fab up a piece to adapt from the Camaro e brake to the T/A e brake if we can see the distance and relationship to each other.
Old Feb 23, 2011 | 04:06 PM
chicows18's Avatar
here is a picture. hope this helps.
Lee74
70-81 Transmission & Differential
Nov 12, 2014 12:46 AM
Direct Camaro
May 27, 2014 07:39 PM
Direct Camaro
May 2, 2014 09:13 AM
1974z28
Jan 29, 2013 10:30 PM
Colt45az1
May 16, 2009 01:26 PM
