1974 Rear leaf spring perch
Old May 27, 2014 | 04:25 PM
Direct Camaro's Avatar
Default 1974 Rear leaf spring perch
The front perch mount bolts just spin. What can I do to get them out? And what options do I have to fix them. How do I get to the nut I do not see.
Old May 27, 2014 | 07:39 PM
v8chvyguy's Avatar
I just went through this on my 79. I torched the head off the bolt, removed the spring mount and got new "J" nuts for reassembly. It's a bear to get the old nuts out, I had to cut them as short as I could, but, it can be done. Use anti-seize when you reassemble and leave the spring bolts loose and torque them with the cars weight on them. I did mine with two 3/4" hand wrenches.
Direct Camaro
May 2, 2014 09:13 AM
ZACK777
Mar 21, 2011 01:55 AM
andre123
Mar 7, 2010 04:53 PM
andre123
Mar 7, 2010 09:17 AM
grndscrpr03
Jan 27, 2005 09:15 PM
