What rear end do i have?
Old Sep 4, 2019 | 06:59 PM
Originally Posted by Chuck Hatcher
I have a numbers matching 70 SS/RS. I know everything is original because it was my fathers car and he was the first owner. I am getting ready to do some work on it and need to know the ratio on the rear end. I crawled under and got the code but I’m not sure about it. If anyone has access to codes, it is COT 0331G 1
E
Look to see if there's a metal tag on one of the bolts that holds the cover on,if so it may have the ratio stamped on it.
If not here's the formula to figure it out. https://spicerparts.com/calculators/...tio-calculator
Old Sep 4, 2019 | 07:28 PM
peterpar's Avatar
Using the second link Y2Keglide posted above shows the car originally came equipped with a 3:07 posi. I copied and posted the chart below.
Rear Axle Codes
COA 2.56:1 COM 2.56:1 COZ 3.73:1 Locking
COB 2.56:1 CON 2.56:1 Locking CRA 3.07:1
COC 2.73:1 COO 4.10:1 CRB 3.31:1
COD 2.73:1 Locking COP 2.73:1 Locking CRC 3.55:1
COE 3.08:1 COR 3.73:1 Locking CRD3.73:1
COF 3.08:1 Locking COS3.07:1 CRE4.10:1
COG3.36:1 COT3.07:1 Locking CRF2.56:1
COH3.36:1 Locking COU 3.31:1 CRG 2.56:1 Locking
COI 3.08:1 COV 3.31:1 Locking CRH 3.08:1
COJ 3.08:1 Locking COW 3.55:1 CRI 3.08:1 Locking
*** 3.36:1 *** 3.55:1 Locking CRX 2.73:1
COL 3.36:1 Locking COY 3.73:1 CRY 2.73:1 Locking
Rearend Code Example: COZ0327GE - (Chevy sourced 3.73 Posi, Assembled on March 27 w/ Eaton Posi)
Old Sep 4, 2019 | 08:13 PM
Chuck Hatcher's Avatar
Default Rear gears.
Thanks. You saved an old man from having to jack up the car again and slide under the car again. ( It ain’t as easy as it once was).
Old Dec 27, 2019 | 05:02 PM
ZL1CAMARO's Avatar
awesome , my 81 has a GM corporate 8.5" 10 bolt. with some small parts of 12 bolt internals and hardened axles. since its street i'm opting for an aluminum housing. also a 40 gallon gas tank. looking to get 40 miles per gallon for 1600 miles per tank of fuel. Designed a 10 speed auto transmission.
Also, designing a mechanized fuel injection and induction system. making a very high torque upper band engine at very high volumetric efficiencies and mechanized timing that can intermittently alternate cylinder fuel and fire in a high rpm high torque engine. Big bore small block
meteoralp45
Feb 15, 2009 07:11 PM
camaro maniac
Sep 23, 2007 10:41 AM
BIGMIKE
May 3, 2007 05:29 AM
cabowaboz28
Jul 29, 2006 01:58 AM
sewerrat
82-92 V8 Tech
Oct 29, 2005 01:34 AM
