Loud noises while driving (driveshaft)
Old Apr 7, 2020 | 01:12 PM
GermanZ28's Avatar
Default Loud noises while driving (driveshaft)
Hi guys,
Since I bought my Camaro it makes these really loud roaring noises coming from underneath the rear seat. I asked a friend and he said it's probably the driveshaft and I should replace it. Are there any other suggestions what my problem could be ? And if you agree to the driveshaft theory where can I find the measures for it to assure I am buying the right one. The car runs a 3 speed automatic btw.
Thank you so much for you help!
Old Apr 7, 2020 | 07:10 PM
Unless the shaft is bent and or out of balance it shouldn't need to be replaced,usually just the universal joints need replacement.
A noise vaguely described like this could be other things,rear differential,transmission, ?
I'd get the car up on stands and check the driveline for play or slop at the u-joints and or slop in the differential ,check the engine and trans mounts and see that the trans is not coming unbolted from the engine.
Old Apr 8, 2020 | 09:02 AM
Zspoiler's Avatar
Put the car up on jack stands and take a look ..It would be easier to check it
Old Apr 8, 2020 | 12:26 PM
GermanZ28's Avatar
Sounds good thank you, I think it's not the differential because to destroy these old differentials I think it needs more than just 88.000 miles of cruising . I also don't think it's the transmission because the sound comes more from the rear and not really from underneath the front seats. I appreciate your advice with the universal joints I'll put the car on jack stands and check for play etc.
97RallySport97
Jun 21, 2012 04:55 PM
libertyforall1776
Nov 1, 2011 02:33 PM
REN
May 18, 2011 11:10 AM
gregsta565
Dec 9, 2010 02:44 PM
Camaron32
Jul 7, 2007 03:51 AM
