Squeeky Driveshaft
Old May 15, 2011 | 06:38 PM
REN's Avatar
REN
Default Squeeky Driveshaft
My driveshaft is squeaking at the front shaft/transmission area. Is there a bushing inside that could be causing this to squeak? Is this prone to squeaky or could it be something else. The driveshaft is new but the yoke is showing rust already too.
Old May 16, 2011 | 06:30 AM
REN's Avatar
REN
Default Squeaky Driveshaft
My driveshaft is squeaking at the front shaft/transmission area. Is there a bushing inside that could be causing this to squeak? Is this prone to squeaky or could it be something else. The driveshaft is new but the front yoke is showing rust already too.
Old May 16, 2011 | 07:10 AM
mrfreez's Avatar
Take out the driveshaft and use some silicone lube for brakes on it.
The yolk is getting hung up on the driveshaft. It just needs to be worked in. Either that or the yolk is smaller then the yolk on the old driveshaft and there's too much space. Either put the old yolk on the new driveshaft or replace the bushing in the tailhusing of the transmission.
Old May 16, 2011 | 08:58 AM
try some lube on the slip yoke and while your under there check to make sure there nothing rubbing on the driveshaft.
Old May 16, 2011 | 04:06 PM
torque_is_good's Avatar
my hunch is that it's not the driveshaft. i betcha it's the torque arm bushing. Apply copious amounts of silicon spray or any other rubber restorer.
Old May 17, 2011 | 08:06 PM
REN's Avatar
REN
Lubed it and it still squeaks, the yoke may be smaller feels like it has some play. Will look at the old one, how would you get the rubber bushing out of the tailhousing?
Old May 17, 2011 | 08:07 PM
REN's Avatar
REN
Old May 17, 2011 | 10:04 PM
does the noise increase with speed or rpms?
Old May 18, 2011 | 07:47 AM
REN's Avatar
REN
Seems to squeak the most at low rpms. If I get the wheels spinning faster by hand the squeak drops. On the road I canoot tell until I am parking and its a definite squeak.
Here is the video, this was taken from the rear but the noise is coming from the transmission tail housing.
YouTube - Driveshaft Squeak
Old May 18, 2011 | 08:51 AM
wow,,, thats a squeal not a squeak. never heard anything like that before. gorn may have an idea. sure sounds like a brake squeal. is this a auto trans?
