Gears or transmission, which one???
Old May 8, 2009 | 10:03 PM
vtcamaro's Avatar
Default Gears or transmission, which one???
I have a question......... I have a 78 camaro with a 402BB and a powerglide trans. When I hit the street, it seems to hit the RPM's a little on the high side when im driveing down the road and eating up a crap load of gas. My question is this..... Should I change the trans to a 3 speed or should I change the gears in the rear end. There are 410's in the rear now. I would like to do it the easiest and cheapest way possible. I DONT want to lose to much on the low end take off but.... whatever has to be done. Thanks for ANY help.
Old May 8, 2009 | 10:51 PM
How much money do you have to spend? Swapping out the powerslide for a t350 will only give you one more intermediate gear. Final drive is the same for both, 1:1. So your "down the road" rpm's won't change, nor will your crapload of gas situation. Considering your 402 has a lot of grunt, I don't see a trans swap as being very beneficial for what you're after.
4.10's are fun. That's what I have, and I wouldn't want to go with a higher ratio. But I plan on replacing my t350 with a built up 700R4. An overdrive trans will give you the best of both worlds, a nice low first gear which would be noticeably lower than what you have now, and overdrive to lower the highway rpm's a good bit.
I would price out both a gear change and a trans, then decide which is more important to you.
tscw96
Mar 26, 2012 09:18 PM
dsinclair999
Feb 21, 2011 11:24 AM
n269nando
Aug 9, 2009 01:27 PM
jamguitarist91
May 21, 2009 07:43 PM
