Trying to figure what springs to use.
Old 11-12-2012, 12:55 PM
Mr.Bill's Avatar
Default Trying to figure what springs to use.
Hello everyone.
I have a 1972 Camaro with a 468 Big Block, It currently has stock small block coil springs in it and I want to install a set of big block springs and keep the stock height, Most I have seen offered for the BB lowers the car 2 inches and that is what I don't want.
Anyone have an idea for my delema? What brand and part number should I be looking for? Car has no AC.
Thanks in advance.
Bill
Old 11-13-2012, 09:57 AM
Originally Posted by Mr.Bill
Hello everyone.
Thanks in advance.
Bill
Just went through this last year on my BBC Camaro. I wanted new springs, but didn't want my car to sit too high. I went to my local spring supplier and ended up ordering new coils for a 2nd gen with SBC and AC. The height was perfect I think. Not as high as those I've seen with new stock BBC coils, but not sagging like old SBC coils in a BBC car.
Old 11-13-2012, 10:06 AM
Mr.Bill's Avatar
Thanks for the input, Maybe I should think about sb coils with ac, The issue I have now is the car seems to bottom out on the coils when I hit a bump, That could be because the coils are weak and lost the tension.
Car sits fine, It is just when I hit bumps.
Bill
Old 11-14-2012, 10:32 AM
Sounds like mushy springs, and a new set will definitely help, but SBC std. coils will probably still bottom out. The SBC AC coils will just add a little, without the nose high effect of BBC coils. You could also go with BBC lowering coils and get the firmer ride, but not bottom out.
Krusher RS
05-23-2013 11:51 AM
Adam9066
06-21-2011 06:18 AM
AP91RS
82-92 V8 Tech
06-14-2011 06:15 PM
90iroc-z28
82-92 V8 Tech
04-10-2009 12:22 AM
Quick Reply: Trying to figure what springs to use.
