which pitman arm
Old Mar 19, 2022 | 08:22 PM
skinny62's Avatar
Default which pitman arm
new b here and need tech help. i have a 1949 chevy panel truck that has a camaro sub frame welded in,i beleive it is 1970- 1974? short outer tie rods ,smaller outer wheel bearing, and a later style ps box with o-ring lines my Q is which pitman arm works with that combo .I put the bent one that came with it on and it drops the drivers side of the steering down about an inch or so lower than the idler side bought the one for 1970-1981 and the linkage is straightbut the hole for the shaft is to small any help figuringit out would b appreciated has all new suspension parts
Old Mar 20, 2022 | 06:44 AM
Everett#2390's Avatar
I would go straight alignment.
Old Jan 9, 2023 | 01:37 PM
grzewnicki's Avatar
nebt3x
Feb 3, 2020 10:52 AM
Savidio
Dec 7, 2019 06:49 PM
GCS
Apr 3, 2019 07:35 PM
91rs350
Jul 29, 2010 12:05 AM
n269nando
May 27, 2010 04:56 PM
