leaf mounted trac bars?
Old May 20, 2014 | 05:26 PM
BLK79's Avatar
Default leaf mounted trac bars?
Are trac bars really necessary on my 79 Camaro with a mildly modified 350 auto, open diff and 2.41 rear gears?
Old May 21, 2014 | 11:04 AM
With your combination I doubt you are going to run into leaf spring wind up problems requiring the use of slapper bars. However, if the bars are already installed, it won't cause any problems.
Old May 21, 2014 | 11:12 AM
If you're in the habit of wanting to leadfoot the gas pedal off the line, your leaf springs will be wrapping up some. Maybe not enough to cause serious traction loss, but slapper bars can help to prevent spring fatigue/breakage. If you do add some bars, don't get the cheesy clamp on style, use the good ones that replace the lower spring plate.
BLK79
May 31, 2014 09:12 AM
nasty50
67-69 V8 Tech
Oct 20, 2011 06:18 PM
maudyZ28
Mar 29, 2010 05:30 AM
camarosrnice
May 14, 2009 09:11 PM
JackOfNines
Oct 1, 2007 08:46 PM
