2" Drop Spindle on 2nd Gen
Old Jul 8, 2013 | 06:44 PM
Cujo's Avatar
Default 2" Drop Spindle on 2nd Gen
I have a 1973 Camaro, with stock 350 engine/auto trans. I have 240/40/18 tires in the front on 18x7 inch wheels. I want to install 2"inch drop spindles to lower the front, which is currently 1 inch higher than the rear of the car. My question is will the front tires rub with the 2" drop spindles? I thought about installing 1" lower coil springs in the front, but I just installed new stock coil springs on it less than a month ago.
Thanks in advance for your assistance.
Old Jul 9, 2013 | 09:17 AM
You'll have to pull more apart to do spindles than to do coils. Plus coils will be way cheaper than spindles. So I wouldn't worry about whether they're new or not. You might even be able to sell the new stock coils for less than you paid and recoup some of the funds, but selling old spindles will be a tougher sell.
And depending on your offset, the new 18" wheels and tires may very well rub with 2" lower stance.
Old Jul 9, 2013 | 09:50 AM
Cujo's Avatar
Yeah, I was thinking the same thing. Worst case scenario I would have to change out the rear leaf springs (which I'm sure wouldn't hurt considering the age of the car) to match the front stance of the car.
I also installed new stock shocks last month when I changed out the coil springs, upper and lower ball joints and A-frame bushings.
Question: Will I have to change out the new stock shocks to a lowering shock to match the 1" inch lowering coil springs?
Old Jul 10, 2013 | 09:02 AM
No, I used stock shocks front and rear with lowering springs. 1" isn't any lower than old saggy coils, so no problem with shocks.
CamaroJoe68
Nov 25, 2016 10:37 AM
red67coupe
Jan 19, 2012 08:31 PM
BigJCamaro67
Sep 17, 2011 03:44 AM
He_named_me_Nicole
May 31, 2009 08:29 AM
Cruiznblue
May 7, 2009 02:14 PM
