Caliper Upgrade??
Old May 16, 2013 | 08:41 PM
Craig80RS's Avatar
Default Caliper Upgrade??
Hello all. My son and I just got a '80 RS project car and are excited to get going. The car needs some brake work (among other things). Question is.. the calipers are single piston and relatively cheap to replace. Is there a multi piston swap from a donor car that is a bolt on upgrade? I see the $300 options from Summit and other vendors. What have you guys done?
Old Jun 1, 2013 | 07:17 PM
Get a set of spindles from a b body. Then use a D52 caliper and a I roc 12" rotor. This is know as the 1Le conversion. Junk yard parts are easy to come by. A Bbody is Impala, Park Ave and Delta 88. These have bigger bearings that work with the Iroc rotors. The lug nuts will need to be changed to metric though.
Old Jul 4, 2013 | 08:20 AM
Zspoiler's Avatar
I depend on what you want to do with the car,and your check book. Because there are some really pricey upgrade out there.
Old Jul 19, 2013 | 08:39 AM
Claireamber's Avatar
You need to go back to the manual and also check out the latest upgrades that have worked before you change the brakes. But I think its possible.
Old Jul 20, 2013 | 09:37 AM
There's a manual for upgrades to tell us what works? Wow! All this time I didn't know they had one to help us!
Old Jul 22, 2013 | 01:37 PM
Zspoiler's Avatar
Power Disc brakes are safer
Old Jul 23, 2013 | 09:08 AM
Safer than what? Any well set up brake system will work great if it's in good condition. The stock power disc brakes are a very good braking system for almost any driving, with maybe the exception of autocross. Many owners go to non power disc brakes on cars used for autocross or racing, as engines built for all out performance don't build enough vacuum to really work well on power brakes.
Power brakes do have one drawback. When the engine dies the braking pressure assist goes away, and it takes a huge amount of pressure to bring the car to a stop.
mab6680
Mar 10, 2014 07:49 AM
silver97
Aug 24, 2011 04:32 PM
pezlow
Jan 18, 2010 09:33 PM
Cammy 3.8lV6
Dec 17, 2009 02:16 AM
