New Build Thread?
#434
I'm going to use steel. Prob 20 ga. I'll use my friends brake. Not too much to bend. I'll X across the middle for strength and just a small top and bottom bend. Using the stock mounting location, the side are pretty close already!
Ps with this rad I need to turn the idler arm bolts around to clear the lower rad hose.
#436
Havn't posted here in a while. I posted about my tranny, I have no park just another neutral. I also wanted to get my speedo correct. I think due to the amount of agg, I 'll just deal with the park think. My parkng brake is fine. That thread is moved to some sub sub section( I think it's near the wiper section).
I prepping for primer now. I'll be a couple of days until I spray due to the weather. It's cold and rainy. I'll be spraying in shifts. I have lots of loose stuff that will require the car outside and I can't access both sides of the car in the garage at once.
