New Build Thread?
#152
Thanks Joe! I don't plan to send it out assembled and I want the inner fenders body color.
77Nomad I was out sanding this am feeling sorry for mayself as I was sanding the plastic parts. Then I thought of you sanding rubber, That must be way worse. I also knew I'd be painting again so I fired up the heater to 65.Very tolerable...
#154
My rubber nose is sitting up on a shelf. I haven't touched it. I scuffed it for the repaint yrs ago and that all has to come off. I am saving that until the end. Its gonna suck. I was out last night filling all the spot welds on the firewall. I also removed the tab that goes behind the master cylinder. The one that holds the wires. I had to fill the crater I made when I ground it out. Then made a better template for the panel to smooth it out.
#155
So I let the fog clear a little. The one in the shop,the one in my head has been unchanged for years!!!
Took some new pics. The fender that I welded together looks great. The other one(the one I chemically stripped) looks like someone beat the top with a ball peen.
#156
Was it because of how you stripped it (You mentioned "beat the top") So is it damaged?
