CRU!NCH TIME - 73 Z28 Build
#31
Got the trunk open for the first time in 20 years! I had to pull the rear seats and used extensions and unbolt the trunk latch. Some how the door/trunk key was lost. However I found a set of keys in the trunk! I was excited to see what was in the trunk.
DSC00802.jpg?t=1303080953
However I didn't find anything too exciting except the keys. which were over here on the side
DSC00805.jpg?t=1303081050
After a little clean up and vacuum out the mice nest, throw out the nasty carpet. This is what was underneath.
DSC00806.jpg?t=1303081203
Got it loaded on the trailer to take to the car wash.
DSC00817.jpg?t=1303081325
It was really easy load with the use to of the engine hoist and winch.
DSC00814.jpg?t=1303081432
It was so worth it, much easier to see what condition it is in under there. It looks really good. just some light surface rust nothing bad at all.
DSC00819.jpg?t=1303081487
I removed the fuel Tank and rear differential next.
DSC00810.jpg?t=1303081725
DSC00811.jpg?t=1303081725
The fuel in the tank stunk up the whole shop.
I left the leaf springs on the differential and just dropped in down it was easier than I thought it was going to be the bolts weren't even rusted I was able to just use a wrench on them they came right off.
DSC00825.jpg?t=1303081922
DSC00826.jpg?t=1303081922
DSC00828.jpg?t=1303081922
too easy.
DSC00829.jpg?t=1303081922
I spent a little time and cleaned this area up a little.
DSC00837.jpg?t=1303082362
Next I'm goint to sandblast the rear diff. and leafs paint. I brought the engine, dash and center console over from my other shop.
DSC00833.jpg?t=1303082181
DSC00834.jpg?t=1303082216
I didn't take any pictures of the center console but it's out of a 02 Camaro just the like dash and gauges.
too easy.
#33
Yeah I was thinking the same thing. I think I'd give it a good cleaning and have a nice survivor. I wish I'd had that much to start with, LOL.
#34
Suck it emissions testing!
Ok this really sucks in Colorado they just started back up with the emission testing and what not. So when I do get my car ready to go on the road I have to to put on the air pump, evap emission stuff and catalytic converts that goes with the 1997 Z28 engine I have. I think it's really dumb considering this engine is going to run more efficient than a 73 carburated 350 engine ever could even with out cats, air injection and what not. I mean its not like putting that stuff on is going to be that big of a deal it's just more stuff I have to mess with Before I can drive this thing on the road.
but n e ways
Just thought I would share this lol. It looks so crazy without the rear axle. the shape of the body looks really neat at this angle.
DSC00839.jpg?t=1303174553
but n e ways
#36
How far back are they going with testing? In Oregon it's 1974 and earlier are exempt from testing. They say if you install a newer engine you need to put that year's DEQ equip. on, but nobody does it, and nobody checks pre test cars to see what engine they have.
#37
I think I'm going to try and sneak it through and see if they catch it they may not even know what they are looking at and just test it haha. 81 and older just have to do idle sampling test while 82 and newer have to do IM240 and run on the dyno for 240 seconds. IF they do catch it I have to set up a special appointment with a special emissions inspector to check out my car and make sure it has everything it is supposed to. The funny thing is all the equipment has to just LOOK operational they won't actually check and test it (they check obd2 codes thats it)... So they wouldn't know if I reprogrammed my pcm not to monitor post cat O2 sensors and not to operate air pump or canister purge.
#38
The never ending and so painful...
Ok So I knew this would pry take me like a week and a half of work to do this a couple hours at a time so I spent all day yesterday doing this and it feels amazing to have this part done!
So I cleaned up the under the trunk area no prob a couple hours. However the rest of the under car was full of nooks and cranies which was such a pain to do, not to mention having to hold the grinder above my head all day. Yeah it pretty much took all day and it sucks using wire wheels constantly throwing little wires at your face, I had to keep check to make sure none of them actually stuck in OUCH. I never want to do this again lol.
But here is how it looks
DSC00846.jpg?t=1303234250
DSC00847.jpg?t=1303234250
In the pictures above it doesn't really look to good but after I cleaned all the dust off with here is what we got.
DSC00849.jpg?t=1303234250DSC00850.jpg?t=1303234250
I really was thinking about sand blasting it but I didn't want to have to mask off the whole car and have to clean the media out of every little hole. Plus it still had a lot of good area with good paint still on it so I left the good parts alone.
So I got on the first coat of primer I'll put a few more today and I'm going to let it set for a few days and put on some undercoating. When I say undercoating I mean truck bed liner.
DSC00851.jpg?t=1303234250
DSC00852.jpg?t=1303234250
#40
Sweet, I hope you used some type of epoxy primer. That is a very nice survivor. Your dad did the right thing putting it away.
Check out my thread, you were saying something about trying to use ABS. There is a pic of the trouble I hit with the ABS sensor.
