Cobalt Blue 79z28
Old 03-09-2012 | 12:11 PM
bad436z28's Avatar
i know the headers on these cars are a real tight fit,can i just install my headers on the engine before i drop it in or do i need to wait and install them after the engine is already installed.
  #472
Old 03-10-2012 | 04:02 PM
I did mine the other day with them on. Take yours off, lol. Then set them in the engine bay and lower down over them.
  #473
Old 03-10-2012 | 06:56 PM
bad436z28's Avatar
ok thx. i can try that havent tried to install my engine yet was just curious if i could attch them to my motor before dropping it in,would make things easier,but i will try setting them in engine bay then dropping the motor in.then bolting them up,will i have problems changing my oil filter with my kick out oil pan.
  #474
Old 03-10-2012 | 07:06 PM
bad436z28's Avatar
did warm up but late today,so i did manage to get a little done,final sanded my door jams with 400 grit then layed my 2 coats of primer on them,now i just need to wet sand them with 600 grit and there ready for paint soon,then i can finally get my doors back on yahhhhh!!!
By bad436z28 at 2012-03-10
  #475
Old 03-10-2012 | 10:55 PM
When I set mine in the other day. Not only did I leave the headers on but I came in from the side instead of the front. Never again! I just didn't have the room to come in from the front. I'm glad I picked up a leveler for the hoist that day. Otherwise the engine would have fought all day.
  #476
Old 03-11-2012 | 01:39 AM
bad436z28's Avatar
yeah i bet,even harder from the side i think im gonna try setting them in the engine bay then dropping my engine in,maybe that will be the easiest.
  #477
Old 03-11-2012 | 01:45 AM
bad436z28's Avatar
some people say there headers drop right in,and others say they fight with them for hours,hope mines one of the easy ones.Lol.some say u must pull ur starter then bolt it loosely then install ur starter,they also say u must remove shift linkage for manual cars then re install after headers are in,and they must go in from the bottom,hope i dont have to go thru all that.
  #478
Old 03-11-2012 | 07:47 AM
5time F's Avatar
There is much to say about shorty headers.... they don't fight you nearly so bad..
  #479
Old 03-11-2012 | 10:36 AM
james hellsing's Avatar
When I installed the headers on my previous 79 I had to go through the bottom and uninstall/reinstall the starter and part of the shift linkage. It was a PITA, so the second time when I was installing an engine I had the passenger side header installed but left the driver side off that way I still had plenty of room to manuver the engine, it worked out pretty good then I either had to go through the bottom for the driver side or installed it while the engine was halfway in can't remember though but goodluck on yours.
  #480
Old 03-11-2012 | 10:44 AM
I think I went through the bottom on the passenger side too. I left the starter on when I pulled it. Left it on when I put it back in. I plan a quick disconnect for the wires in the future.
The setting them before hand idea is almost fool proof though. Like I said I got mine in but I dont have any sheet metal on and the collectors scratched my freshly painted floor pans. Good thing I used rustoleum. I can touch it up pretty easy.
Quick Reply: Cobalt Blue 79z28
