Cobalt Blue 79z28
#231
ok i can do that,so what u thinking maybe a 2200 or 2500 stall convertor would be best for all around use.maybe i could mount it on my firewall somewhere its not gonna get banged up where u got urs mounted,or i could mount on the drivers side where the charcoal canister used to be ,its usually cooler over there lots of fresh air coming thru.
#232
hugger orange or synergy green.
hey guys u wont believe this but ive totally changed my mind about the blue,too many camaros already blue,im either gonna paint it hugger orange my favorite color or synergy green ,i love that color just not sure how it would look on a 2nd gen.both colors would get white stripes.
#233
I'd check cruising speed rpm's and get something that's equal to your cruising speed at 55-60mph, or slightly lower. If your engine runs 2500 rpm's at 55mph, then go a little lower. My '71 cruises at 55mph around 2300, so I went 2000, and the Austin cruises around 2500, so went 2200 stall.
I've got my cooler mounted in front of the radiator on my '71. On the Austin I mounted it horizontally below the radiator, because it's got a tiny radiator and I didn't want anything in front of it. You can see my cooler in front of the radiator in this old pic from the bodyshop:
#234
yeah thx val i think that would fit nicely there on mine,my cooler looks the same exact size as yours.
i think my camarto is gonna cruise right around 2,000 with a 400 turbo and 3.08 gears not sure wich gears u have.
#236
You can't put the cooler on the firewall. It needs to be like Vals with air going through it.
That support is rough. If you are going to convert your car to an earlier model, look for a parts car. You may get a better support. You will need lots of misc stuff anyway not just sheetmetal and bumpers.
#237
yeah i been searching for an older front clip but not much luck,i fonund one for 500 but it was worse than what i already had,i will search a little longer if not i will just keep it an 80 front end,atleast i know what im getting into there and i have all the miscelaneous parts.
#238
but the problem is i need to also make room for my intercooler,by the radiator, i dont wanna block my whole radiator. once its broke in,it will get twin turbo chargers.but it will be awhile before that happens.
#240
Yeah, there is a point where the car just wont take more HP. You'll find that the body will tweak and you'll see that when the seam between the roof and quarter panels start to crack; most likely the driver's side first. It's pretty common on the 2nd gens when people start pushing the HP too far without going to a full chassis.
I'm running 3.42 gears in the Camaro and 3.73 in the Austin. The 3.42's are the perfect gear combo for decent accelration with an automatic, and still maintain a good cruising speed rpm with a TH400 or TH350. The 3.08's will really allow you to wind out on the freeway.
