79 Camaro Project
#751
Don't forget.
#753
OK, I doubt it needs to be all that accurate. Just measure top of hole to top of hole or something, that would be the same as center to center. A regular ruler would be fine, I would imaging that getting it within 1/8" would be more than good enough.
#756
It looks simple enough. Does the 5/8 represent inches? If so I got it then. Thanks, I"ll get some made up.
So 4 1/4 less 3/4 is 3 1/2" center to center on the holes, which is what my stock one is. I'll go with that, I'll just get the beefier ones made up. What is the purpose of the bottom hole then do you know?
#757
Yes, 5/8 diameter. That is what the circle with a line through it represents sorry. I see it on prints all the time so I didn't even think twice about it. The two holes farthest apart are for the stock location. The next will lower about 1/2". Even though the hole moved 1". Not sure how that works. I have mine that way but haven't done the Herb Adams mod yet.
#758
Because the rearend is approximately at the half way point of the length of the leaf spring. At the front spring eye, it moves 0".
