78' RS Build in MA - "The Moss-maro"
#273
No my horn doesnt blow . . . literaly !
run that by me again. stock horn, no wires. Grant horn, one wire on the hub, one lead which needs a wire but doesnt have anything going to it . . . .
#276
maybe i should post pictures of what it looks like . . . theres one wire connected to a ring on the hub that has a connector that matches the connection on the underside of the horn button (male to female) There is a second male connection on the underside of the horn button which im assuming is for power (if the other one is the ground) but were does the power come from . . . . ?
#277
I believe power comes from the horn relay. Power goes to the relay, so when you ground it the relay pulls in and the horn is powered.
