78' RS Build in MA - "The Moss-maro"
Old 12-18-2011 | 10:13 PM
walkingchaos's Avatar
I need to replace pretty much every single suspension bushing under it to make it stick to anything lol
  #292
Old 12-19-2011 | 08:22 AM
bad436z28's Avatar
but when u do it will ride like a dream,you will love the new bushings,makes a huge diffrence in the way it handles,myself i like the energy bushings.
  #293
Old 12-19-2011 | 10:45 AM
I used Energy Systems poly bushings, and bought the extra 8 oz. grease that Summit sells for lubing them at install. Also polished the metal inserts prior to installation, and added lots of lube at assembly time. Seems to really work good now, and handles great!
  #294
Old 12-19-2011 | 11:26 AM
bad436z28's Avatar
yeah u have to lube them pretty good to get them to fit right,they also say if u freeze them first makes installation easier,never tried that,but they sure do make it handle better,well worth the money.
  #295
Old 12-19-2011 | 11:38 AM
If you freeze them don't forget to heat the control arm.
  #296
Old 12-19-2011 | 03:46 PM
does anyone sell a complete kit of bushings for the 78 Camaro ?
  #297
Old 12-19-2011 | 05:06 PM
bad436z28's Avatar
yeah u can buy the energy master kit has evey bushing for the whole car.
  #298
Old 01-01-2012 | 07:11 PM
bad436z28's Avatar
happy new years hope u have good luck on ur resto in the new year.
  #299
Old 01-01-2012 | 08:06 PM
I got mine from Summit, and they are Energy Suspension. This is the kit I bought for $165 back a couple years ago. It's under $200 still. It doesn't have the bushings for the swaybar mounts, but I bought those separately for under $10 for all 4 at NAPA.
Energy Suspension 3-18116R - Energy Suspension Hyperflex Bushing Kits - Overview - SummitRacing.com
The installation lube isn't for pressing them into the control arms; it's for lubing the friction points on the poly bushings. I used it inside the upper and lower bushings where they pivot on the A arm shaft, and inside the lower bolts and frame points. Also used them on the top and bottom of all the body bushings, and leaf spring bushings.
I've heard what happens when poly bushings are installed dry and they creak and squeak when the arms go up and down. Didn't want that for sure!
  #300
Old 01-01-2012 | 10:06 PM
Thanks guys, ill consider that come spring when she gets worked on again. On the plus side the carb is coming off and a good friend of mine is rebuilding it and doing some trick stuff with it (dont ask me what)
Quick Reply: 78' RS Build in MA - "The Moss-maro"
