78' RS Build in MA - "The Moss-maro"
Old Nov 9, 2011 | 12:11 PM
  #271
rydeer's Avatar
The horn button connects that wire to ground. Then the horn blows!LOL
Old Nov 9, 2011 | 12:21 PM
  #272
Your horn blows. Ha!
Old Nov 10, 2011 | 08:25 PM
  #273
walkingchaos's Avatar
No my horn doesnt blow . . . literaly !
run that by me again. stock horn, no wires. Grant horn, one wire on the hub, one lead which needs a wire but doesnt have anything going to it . . . .
Old Nov 10, 2011 | 11:47 PM
  #274
Stock horn has a wire to the ring. The ring runs to ground.
Old Nov 11, 2011 | 03:20 PM
  #275
B.M.'s Avatar
The little wire that looks like it doesn't go to anything,you put it under one of the screws that holds the wheel to the hub,and that gives the horn button a grounding point.
Old Nov 12, 2011 | 03:16 PM
  #276
maybe i should post pictures of what it looks like . . . theres one wire connected to a ring on the hub that has a connector that matches the connection on the underside of the horn button (male to female) There is a second male connection on the underside of the horn button which im assuming is for power (if the other one is the ground) but were does the power come from . . . . ?
Old Nov 12, 2011 | 05:18 PM
  #277
I believe power comes from the horn relay. Power goes to the relay, so when you ground it the relay pulls in and the horn is powered.
Old Nov 14, 2011 | 07:50 PM
  #278
ok that makes more sense . . . thanks
Old Nov 14, 2011 | 08:01 PM
  #279
On a side note my son was born yesterday so work on the Camaro is on pause . . . prob till spring 7lbs 4oz, 22inches long, mom and baby are healthy and doing great
Old Nov 14, 2011 | 10:46 PM
  #280
Congrats!
