76 Fuzz buster
Old 03-05-2012 | 10:36 AM
oldman9's Avatar
Originally Posted by 77nomad
I would move on unless the budget just won't allow it.
I was doing some research on google and found a nice cutaway of the heads. I've done port work on harley heads before with some good results.
I think I can just get rid of the tooth looking bit, but I wanted to ask you guys first....
  #52
Old 03-05-2012 | 11:01 AM
It will definitely help. Just don't get crazy. But now you know what I was getting at with them being crap. Maybe work the short turn just a bit.
  #53
Old 03-06-2012 | 04:12 PM
oldman9's Avatar
I removed the left head and found ALOT more sealant. I found the exhaust valves are not seating properly. I removed the carbon build-up and got rid of the ramp looking thing that stuck out. I'll start on the intake side after I figure out how to get the valves seated the right way. I also found that the head gasket was not sealing in between the cylinders. Any thoughts on why that would be?
Attached Thumbnails 76 Fuzz buster-5.jpg   76 Fuzz buster-4.jpg   76 Fuzz buster-ghj.jpg   76 Fuzz buster-6.jpg   76 Fuzz buster-3.jpg
  #54
Old 03-06-2012 | 05:30 PM
5time F's Avatar
Use a straight edge on the block and the heads.. see if they are warped... if they are not warped then try a set of Permatorque gaskets and keep an eye on the compression ratios on the Cylinders..
  #55
Old 03-06-2012 | 08:01 PM
oldman9's Avatar
I checked the block and the head. Both are straight, thank goodness....
Got some valve lapping compound that came in two grits. It worked very well.
I will start smoothing out the passage ways and flush the coolent chanels in
the morning. After I get this head put back together, I'll start on the right side
one and then install them on the block at the same time.
  #56
Old 03-06-2012 | 11:36 PM
The bright side is its a roller block.
  #57
Old 03-07-2012 | 03:41 PM
oldman9's Avatar
I finaly got the ports cleaned up and steam cleaned. After the paint cures, I want to scrape it off of the letters on the intake. Its getting there I guess. At least the other head will be easier to do.
  #58
Old 03-09-2012 | 08:24 AM
oldman9's Avatar
Today I got started on the right side head cleanup.
I remove each rocker arm and push rod one at a time to make sure I did not get them mixed up. I noticed that on the number 8 cylinder, the intake side push rod looked to be worn down a bit. In the side by side picture below with the exhaust push rod, You can tell the deference. What do you guys thing went wrong?
  #59
Old 03-09-2012 | 10:44 AM
Age. The push rod could have gummed oil in it stopping flow to the rocker. Many things really. I would look at the cup on the rocker too. Also the the pivot ball. Really it just looks like a well worn motor to me.
  #60
Old 03-09-2012 | 11:20 AM
5time F's Avatar
is that the lifter end or the rocker end... if the rocker is worn too you might need to replace them both...
Quick Reply: 76 Fuzz buster
