76 Fuzz buster
#191
I pulled off my bumpers on my 76 [ what was GM thinking ] all the tons of springs and brackets.I threw it all in the trash and hung them back on brackets i made.Over 85# of weight i removed.Looks like your making good headway on your car...that ford horn is too funny....lol
#192
I drove her into the town about 30 miles away to get my tags and paperwork.
Heres the good and bad things that I made note of.
The good.
Cruse like a cadillac eldorado in a straight line.
Tracks well without any pull to the side.
Not to much exhaust sound.
The bad.
The dash rattles like its got a jar of quarters inside it. lol
It coughs when you try take off from a stop. (Maby the accelerator pump or fuel/air mix)
The break lights are very dim in daylight. (maby a bad ground in the trunk)
Thoughts?
#193
Today, I was poking around in the dash. I found where some of the bracing had cam lose and I noticed that none of my gauges where working ecept for the MPH. (its cable driven) I removed the cluster and found that some of the printed circuit was not attached properly. I've not reinstalled it yet, but I wanted to ask if any ones had any luck finding a wiring diagram?
#196
Its fine, thank you. She looks VERY sharp. Did you haft to do a mini tub to fit the rear tires/wheels on it?
#200
We did that to a buddies truck except we traced the outline of the end of the bumper and tucked it right into the fender a 1/2". Looked factory after he spent a month of night in the garage shaping it and smoothing until the fender looked stamped to fit around it.
