383 build/need advice
#21
so i called lunati,comp and crane. comp was the least helpfull crane was great bu lunati impressed me and we came up with this hyd roller Voodoo Retro Fit Hyd Roller Cam - Chevrolet Small Block 282/290 - Lunati Power wich is part of the voodoo line
282/290 duration
535/.550 lift
110 seperation
282/290 duration
535/.550 lift
110 seperation
#22
Make sure you budget the cost of lifters, because roller lifters cost considerably more than flat tappet ones. What block are you using? If it's a non-roller block, you need roller lifters that either have a link bar that ties two together so they don't spin, or conventional rollers with a retro-fit spider plate in the lifter valley. Also, a thrust button on the front of the cam using a rigid timing chain cover, or a chain cover with an adjustable thrust control. However, if you're starting out with a roller block, you'll have it a little easier.
#23
I would never think of doing a retro fit roller set up. Start with a roller block from the factory and go from their. You have all the stuff and not spend the $400 for the lifters. The only one I would do is a 400 block. I have done 3 of the 383 roller blocks and it just simpler to do. Order the one pieces seal kit and bolt it together.
#24
well sorry camaro guys i found a nice 66 malibu that im almost certain im goinng to use for this project i still cant figure out how to post pics but its pretty clean in all the right places post quarters just needs little surface rust removal here and there eh.
couplne new front fenders saome paint and shes golden
#26
![Icon Munching](https://camaroforums.com/forum/images/smilies/icon_munching.gif)
#29
![Icon Duck](https://camaroforums.com/forum/images/smilies/icon_duck.gif)
![Icon Smile](https://camaroforums.com/forum/images/smilies/icon_smile.gif)
