1970 build....
Old Oct 16, 2014 | 09:02 AM
  #41
meanstrk's Avatar
I lost the air pump right after I bought it.
What's the typical tank vent routine? I figure I can cap two of these and run one back up to the evap system or something.If this is a vented cap though, perhaps I can just cap all of them?
Old Oct 16, 2014 | 11:02 AM
  #42
If using a vented cap, you can block off the other fittings. Unless the gasket leaks, the vented cap only vents in, not out.
Old Oct 16, 2014 | 12:43 PM
  #43
meanstrk's Avatar
Good to know.
The bad news is that my sending unit seems to be bad, so I may have to go ahead and get another one. I get a reading when it's at the empty level, but as soon as I move it it goes to an open on the meter.
Old Oct 16, 2014 | 07:42 PM
  #44
joelson6's Avatar
i had to make a vent tube for our tank. i found one of the vent fittings and connected a long 5/16 fuel hose to it. i ran it up over the axle to the highest point under the body that i could find and attached it there. it doesn't look pretty but it works.
Old Oct 17, 2014 | 09:28 AM
  #45
meanstrk's Avatar
I think I have a problem that will only be solved by fabrication. My car originally had A/C. I am thinking about putting just heat in it now, but from what I can tell, the cowl is different from A/C and no A/C cars, so in order to have an air box for the blower to work, I may have to make one to work for my cowl in order for everything to work.
Course, I could always just go with my original plan to not have heat at all....
Old Oct 17, 2014 | 10:37 AM
  #46
Pop the cover off the sending unit and bend the wiper on the potentiometer underneath the cover. Clean the windings also with a little steel wool. Then check it with a meter to see how it reads throughout the travel. I've fixed several Chevy sending units this way.
Old Oct 17, 2014 | 11:11 AM
  #47
meanstrk's Avatar
Easy enough to try. Thanks.
Would you happen to know if this sending unit/fuel pick up diameter flows enough to feel 500hp?
Old Oct 17, 2014 | 03:54 PM
  #48
meanstrk's Avatar
I took the sending unit cover off and cleaned everything and am now reading 35ohms at the lowers to 145ohms. Nice!
Old Oct 17, 2014 | 06:45 PM
  #49
meanstrk's Avatar
Gotta do one thing at a time, right? I started cleaning up the gas tank today to get ready to paint. I had to pull the fuel level sensor apart to get it to work correctly as well and managed to clean up the tank hanger straps and got those painted. I think that was the first part I have actually felt like I completed something!
Old Oct 18, 2014 | 06:44 AM
  #50
Can't say for sure, but it fed my 427 with no trouble, and it was probably around 450 hp. I ran a mechanical fuel pump to a 750 Holley.
