wiper motor
Old Jan 22, 2008 | 03:08 PM
strokerboy's Avatar
Default wiper motor
im in tha last stages of building my 76 i jus dropped in my 383 and i was wondering if anyone may have a wiring diagram for tha windshield wiper motor... thanx
Old Jan 22, 2008 | 04:49 PM
bowtieguy's Avatar
July 2009 ROTM
Default RE: wiper motor
go to www.nastyz28.com .dont know what kind of problem you are having but when i rebuilt my 78,the wipers worked one minute not the next.i couldn't figure it out,had it apart,cleaned eveything,still nothing.i ended up putting a ground wire,from the brass ground strap to the firewall and haven't had a problem since
Old Jan 23, 2008 | 03:25 PM
strokerboy's Avatar
would any ground to tha firewall work?
Old Jan 23, 2008 | 08:24 PM
bowtieguy's Avatar
July 2009 ROTM
best i remember i used the mounting bolt that the brass strap was grounded to,hooked one end of ground there and took it to the fenderwell.there was a hole in the fenderwell that needed pluggin anyway,used a nut and bolt and grouned it there.it was towards the rear so it's not noticeable or if you can find a place to put it on the firewall as long as you scrape it clean
Old Jan 24, 2008 | 02:58 PM
strokerboy's Avatar
i tried grounding it to tha firewall and directly and i get a ticking noise but thats all and its a brand new motor??????????????
Old Jan 25, 2008 | 09:37 AM
1969 SS's Avatar
if your getting a ticking, then everything is working but it is binding up somewhere
jenz
Jan 13, 2015 01:19 PM
wardee
Mar 13, 2012 09:17 AM
lcd69z28
Sep 14, 2006 07:48 PM
