wiper motor
im in tha last stages of building my 76 i jus dropped in my 383 and i was wondering if anyone may have a wiring diagram for tha windshield wiper motor... thanx
RE: wiper motor
go to www.nastyz28.com .dont know what kind of problem you are having but when i rebuilt my 78,the wipers worked one minute not the next.i couldn't figure it out,had it apart,cleaned eveything,still nothing.i ended up putting a ground wire,from the brass ground strap to the firewall and haven't had a problem since
RE: wiper motor
would any ground to tha firewall work?
RE: wiper motor
best i remember i used the mounting bolt that the brass strap was grounded to,hooked one end of ground there and took it to the fenderwell.there was a hole in the fenderwell that needed pluggin anyway,used a nut and bolt and grouned it there.it was towards the rear so it's not noticeable or if you can find a place to put it on the firewall as long as you scrape it clean
RE: wiper motor
i tried grounding it to tha firewall and directly and i get a ticking noise but thats all and its a brand new motor??????????????
RE: wiper motor
if your getting a ticking, then everything is working but it is binding up somewhere
