Wilwood 69-96 BP-10 GM front brake pads D52 Question, any good ?
Old May 3, 2018 | 11:48 AM
stox58's Avatar
Default Wilwood 69-96 BP-10 GM front brake pads D52 Question, any good ?
1969-96 Wilwood BP-10 GM Front Brake Pads (GM Type D52 - 1 Piston Calipers) - Continued
Hi,
Has anyone had any experience using these pads ?
I need to know if they perform well under normal street use, or are they only good for track use when they get up to temperature.
Info below taken from Classic industries
Thanks from Luke
Wilwood's exclusive BP-10 is an all new type of high performance street compound. BP-10 exhibits the medium to high temperature friction characteristics of a semi-metallic based race compound with the low temperature response, quiet engagement, longer wear, and lowered dust levels normally associated with ceramic based street performance pads.
The combination of these characteristics make it the perfect choice for your street machine, auto crosser, or drag racer.
Sold as an axle set.
Note: No further discounts apply.
Applications:
1969-81 Camaro
1969-81 Firebird
1969-96 Impala / full size (except 1993-96 Taxi or Police and 1994-96 Impala or Caprice wi th four wheel disc brakes)
1969-79 Nova
1969-79 X-Body
Everett#2390
Jul 23, 2017 10:02 AM
stockpile
May 31, 2011 07:18 AM
gambit
Jun 29, 2010 06:18 PM
jonnieboy73
Jun 26, 2010 11:57 PM
2001CamaroSS
LS Series Tech
Dec 8, 2005 09:28 PM
