Wheels
Old Feb 12, 2011 | 08:39 PM
78maro's Avatar
Default Wheels
Can some one tell me if these wheels would fit I have a 78 camaro
BOLT PATTERN: 5 x 4.75"
SIZE: 18" X 8"
OFFSET: +2mm
BACKSPACING: 4.50"
Old Feb 12, 2011 | 08:54 PM
ATM's Avatar
ATM
Old Feb 12, 2011 | 08:58 PM
ATM's Avatar
ATM
It should clear. You could even go wider, but you would need to go deeper backspace. I've seen alot of 10" rims, but with 5.5" backspace, and sometimes maybe a 3/8" spacer to kick it back out from the suspension. You may have to take a BFH to the seatbelt hump too though.
Old Feb 12, 2011 | 09:23 PM
78maro's Avatar
thanks alot so those would clear with out any mods right? i wouldnt want to go with 10" though thanks so much eveyone is very helpful on this forum
Old Feb 12, 2011 | 09:28 PM
ATM's Avatar
ATM
If you plug the data into the tire calculator, and scroll all the way to the bottom it tells you that it will fit. I'm sure it will. It really isn't much bigger than what we currently have stock.
Old Feb 12, 2011 | 09:48 PM
LOL the wheels I got on order are 17x11" with 5.75" BS So yeah Your good. The BS might be off for the fronts. I think mine are 17x8" w/ 5.25 BS but I have to check.
Old Feb 12, 2011 | 09:51 PM
78maro's Avatar
Awesome thanks again
77nomad whenever you mount those puppies on how about some pics im still between 17's or 18's
Old Feb 12, 2011 | 09:52 PM
I'm on a 4-6 week wait. But they will be posted for sure.
Old Feb 13, 2011 | 03:17 AM
jason7504's Avatar
dang those are some big wheels lol..what size tires are you gonna use?
Old Feb 13, 2011 | 09:00 AM
315/35r17 and for the front a 255 but I'm not sure on the profile. Its close, but I've seen it done and have done my home work. The wheel is right under the lip and the seat belt hump needs the heat and beat.
