Whats it worth? 71 rs 4spd air solid car
Old Jan 24, 2009 | 12:34 AM
DUNE DICER's Avatar
Default Whats it worth? 71 rs 4spd air solid car
OK, I have a chance to buy a VERY SOLID, no rust anywhere!, just painted,forest green car, paint is BEAUTIFUL, doors fit perfect, straight as an arrow, I'm guessin it was a 5k paint job ,,it is a 1971 RS, its supposedly all there except the radiator and the motor, the front end has been rebushed with urathane and the front has new brakes also the front suspension has new springs with upgradesd parts,,some kind of upgraded ball joints and steering componets. it has a 10 bolt with muliti leaf. a "M21" trans that needs to be rebuilt,,it is not a matching numbers car. it looks like a kit car that needs to be assembled, it is a roller.
Green interior that has been dyed.
OK the seller thinks it might have come with a big block...how can I tell for sure???,,,it has AIR, i was told the air compresser area is smaller if it came with a big block, is that true??? also every big block came with a rear sway bar??is that true?
No, the build sheets are long gone, no gas tank either, help!! i know a solid base when I see one but
Old Jan 24, 2009 | 04:59 AM
Rand's Avatar
I have a 70 big block, but its the 375hp, and none of the high performance engines had air, so I am not sure about the compressor area.
It has a rear sway bar, but thought most, if not all did. But the 10 bolt sounds a lil weak for a big block.
Tag # should have some info, but not sure how much.
But the bottom line is its not a numbers car anyway, so why worry about which motor to put in? Go with the rat motor!!
Get the 572 crate engine and don't look back.
Old Jan 25, 2009 | 09:41 PM
DUNE DICER's Avatar
Main reason I'm asking is so I get the right ride height, if I put a smalll block in it and the springs are for a small block,,,etc,,thanks much for the info and your ideas.
Also the 4 spd is a MUNCIE did those come with small blocks?
Old Jan 25, 2009 | 09:43 PM
DUNE DICER's Avatar
Hey RAND, also, I heard only the 70's came with 12 bolts then in 71 even if it had a big block they still hung a 10 bolt in there,,,geez,,, your 70 is the end of the muscle car era,,went downhill fast after that eh??i
Old Jan 26, 2009 | 12:31 PM
WICKEDBOWTIES's Avatar
the 1970 camaro was the end of the 12 bolt in the camaroand you could get air with the big block and yes the munci was available
Old Jan 26, 2009 | 10:42 PM
DUNE DICER's Avatar
Default reply
Hey thanks for the info,,now a new Q...the code o the rear end is " 2PC G060_, the last nuber was unreadable...i have searched sites and the first digit the "2" throws me i cannot figure it out,,ne ideas??
Also the muncie code was a wierd one also it was "P0403" ,,yes its an aluminum munce got that much figured for sure but cant tell whick gears,, gotta open it and look I guess,,,unless you know?
Thanks again for playing!
carman63
Jun 23, 2014 07:14 PM
nickb123
May 19, 2012 06:17 PM
kdankenb
Aug 13, 2008 05:48 PM
94z28chevy
Jul 8, 2008 03:27 PM
Z28midwest_08
Jun 12, 2008 03:08 PM
