View Poll Results: What should I get now?
TH400
37.50%
'70 camaro housing
25.00%
Pypes 3" exhaust
37.50%
Voters: 8. You may not vote on this poll
what would you get first with $500?
Old Feb 1, 2011 | 03:48 PM
  #31
A rebuilt one for that price? What's their name?
Old Feb 1, 2011 | 04:20 PM
  #32
ATM's Avatar
ATM
http://chicago.craigslist.org/sox/pts/2184537078.html
I think that this is the place. I see their ads all the time in my searches for a 4l80e... I do believe it requires a core though, but I'm wondering if any core will work. If not, what is the value of a core? A couple hundred?
Old Feb 1, 2011 | 04:21 PM
  #33
ATM's Avatar
ATM
Old Feb 1, 2011 | 04:43 PM
  #34
jason7504's Avatar
well it's $2400 for a manual 4l80 with mechanical tailhousing to run a mechanical speedo plus $500 for custom converter so close to $3k. It's not a built 4l80 but rebuilt with all new parts and duel fed direct clutches. That's all you need for about 750hp. I can get a stock rebuilt 4l80 locally for $1100 and could just add a manual kit for $150 plus $500 for converter and $500 for mechanical tailhousing kit which would put it at around $2350 so a savings of around $700. I could do that too..and have enough for new crossmember, driveshaft shortened and new exhaust
Old Feb 1, 2011 | 07:42 PM
  #35
jason7504's Avatar
damn the local guy that rebuilds 4L80's for 1100 said that doesn't include the core charge and that is usually around $500..hmm i guess it's either the 4L80 w/ converter for $2900 or a built th400 and custom converter for $1600
Old Apr 9, 2020 | 03:39 PM
  #36
ZL1CAMARO's Avatar
Get a 4L80 for 800 then build it with parts like a revised valve body and change weaknesses and weak parts as required.
And definitely do some T top bracing .
And get the 70 housing 12 bolt because the track width and strength are far more valuable a thing and a hard find.
And is the most universal out of the other parts that you may not end up with a perfect fitting combination.
Old Apr 18, 2020 | 12:30 AM
  #37
Al Loyrat's Avatar
Jason, are you getting the $1200 stimulus? Put some C clip eliminators on that 12 bolt, and go 3" exhaust..
jason7504
Oct 14, 2009 09:19 PM
weaz4200
82-92 V8 Tech
14
Dec 8, 2008 08:52 AM
MusicMan
Sep 29, 2008 06:25 PM
beast85
Feb 6, 2006 11:25 AM
lt4dogman
Mar 15, 2005 02:43 AM
