What Engine...?
#42
#43
What did you decide on? I'm just curious because thats sorta what I'm going for too. Although I'm planning on staying with a small block and one of my (cheaper) options is just rebuilding the 350 I have.
#44
well after tons of deciding and researching between going with a 383 or big block.i found and decided on this 454 with 510hp and 560tq with 10:1 cr. its got good parts and a warranty and is fully turn key with belts, carb and alt and starter..its the most power that's really "streetable" that i could find in my budget. its also dyno'd and dyno tuned and broken in on the dyno
its 6400
its 6400
#45
Very nice! That's a little out of my price range...actually 5000 is a little out of my range, but I'm thinking that instead of spending 3500 or so on my stock 350, that I might as well just spend a little more and get a decent crate motor with some good HP and a warranty.
#46
yeah too much hp and too big a cam and its not streetable. so this is the most streetable 510hp i could find in my price range
yeah if u can find a crate for around 3500-4000 that would be good but you could build up your 350 to a 383 for around 3k and that would save you a few thousand that you could spend on other stuff like rear but then no warranty. since you will need a new rear end and/or tranny depending on how much hp and tq you want
you could build your 350 to a 400 plus hp 383 for a few thousand less than a crate and use the extra on your tranny or rear end. but its up to you. try and find the best bang for the buck and do lots of research.
#47
Problem is the heads, intake, carb, and all that that I want to put on my 350 would cost a few thousand...and it would be pretty hard for me to stroke it out to 383 without spending a bunch more money on it. I have a feeling the block is only a 2 bolt main...so too many mods and I'd be looking for a 4 bolt main anyways. Thats why for 5000 for a 383 (or less for a 350) is almost worth the little extra it would cost up front. Eventually I'd want to put a new motor in the car anyways...so idk...gotta figure out whether the engine I have is worth rebuilding and/or if I want to just spend the extra money and go for a crate engine. The nice part about getting one of the crate engines I mentioned is that almost all of them are already built for max HP...I mean they have good heads, intake manifolds, ignition, etc. already on them.
#48
you could always get a engine from the person im getting mine from..he has some 350's and 383's
here's a nice 383
http://cgi.ebay.com/ebaymotors/SB-CH...Q5fAccessories
a nice turn key 383 but a lil out of ur budget
or this turn key 350 with a lil less hp than u might want(375hp). but under 4k.
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
and if you decide on them, let him know i sent ya
here's a nice 383
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
#49
