what Camaro do I have? help with decoding!
Old May 18, 2017 | 09:36 PM
domc's Avatar
Default what Camaro do I have? help with decoding!
I've inherited a '70 which I was told was an RS SS. It's been stripped down and pulled apart. I have attached a pic of the ID plate. How can I tell what it was and what colour/trim/driveline it should be? thanks heaps!
Attached Thumbnails what Camaro do I have? help with decoding!-camaro-id-plate.jpg
Old May 19, 2017 | 02:11 PM
peterpar's Avatar
I'm not very familiar with the second generation production numbers, but I was able to find this site that might help. The car was built in Los Angeles in the second week of May in 1970. The color is Autumn Gold and the interior is a Sandlewood standard bucket seats. Doesn't look like there is a way to determine the RS/SS trim package or the drivetrain from this tag.
Old May 20, 2017 | 08:02 AM
RS will be tuff to prove without original documents, If you have the original numbers matching engine that would be poof of the SS. The engines they put in the SS's where not available in non-SS's. if you don't have the original numbers matching engine then I don't see a whole lot of reason to prove if its a SS.
Old May 20, 2017 | 08:46 PM
35thLE's Avatar
look above heater box behind dash or on top of fuel tank or stuffed in the rear seat cushions for a build sheet, without it you can't prove anything on these cars, just about everything could be special ordered if you had the right dealer connections back then.
hugger1
Sep 26, 2016 03:49 PM
lubers
Apr 1, 2012 04:22 PM
projectszero
Jul 25, 2007 01:15 PM
1968CamaroFl
Oct 19, 2006 10:58 PM
