Water coming into my 79 Camaro from firewall
I have water coming down my fire wall into the car after a good rain. I have no mouldings around my front windsheild becuase Iam in the middle of a restortion and water in collecting on the flat pan right in the corner where the glass .Fender,and hood hing meet. Water just sits up there. On the pass side I noticed the water coming door behind the heater box and on the drivers side just above the high beam switch.
Any suggestions on what to do.
Thanks
Angelo
Thanks
Angelo
I've seen people drill holes so the water leaks elsewhere, or maybe you have some rust holes down in your cowl area? Tarp it in that area for now or worst case scenario silicone.
Thanks Joe the only problem with drilling holes is where? it looks like that area where the water sits is above the firewall in the car. So if I drill holes the water will go staight in side unless someone knows exactly where to drill these holes
Thanks
Angelo
Thanks
Angelo
Once you find the bottom drain holes just blow the line clear with air. Be sure your hood is open as it will blow upwards and make a mess inside the engine compartment that will need cleaning.
Thanks Guys I will need to still look into this problem, I threw my back out and I have not touched her for over a month. My wife is so happy the other woman ( My 79 Z28 ) is not taking all my time ha ha ha lol.
Angelo
Angelo
350ci-chev-newb
10-23-2012 08:32 PM
ToddB
01-17-2012 06:58 PM
