Bad sound coming from my camaro. Help!
Old Mar 10, 2010 | 09:28 AM
Trollsmeesh's Avatar
Default Bad sound coming from my camaro. Help!
Ok, so my 3.4 V6 camaro started making a..squeaky..noise. I can't figure out what it is though. I can even hear it over my new exhaust system. Needless to say, I can't feel very awesome in my baby driving down the road with this annoying noise.
It starts to squeak when I turn the car on, and it seems to get louder as I accelerate. Here is the weird thing, every once in awhile it will stop altogether.
I need some insight guys, please help my baby sound good again.
Also, I took the time to upload a 30 second video showing exactly what is happening. Hope it helps.
http://www.youtube.com/watch?v=dc4q_sYON6A
Old Mar 10, 2010 | 10:04 AM
torque_is_good's Avatar
Well, you've probably come to the conclusion that it's coming from either the alternator, A/C or PS pump. I don't know the under hood of the sixer but if the alt belt is separate from the P/S and A/C, undo the belt for the A/C and P/S and try it. If the noise goes away, you know it's one of the 2. If it doesn't, then it's the alt.
You could also try an engine stethoscope (about $10 on line) to pinpoint the noise.
It takes a trained ear to be able to pinpoint which one of those rascals is making the noise because it's loud under the hood..
Old Mar 10, 2010 | 01:32 PM
dc14u2no's Avatar
could also be the tensioner if there is one on a v-6.could try a piece of hose to your ear and try to determine which it is
Old Mar 10, 2010 | 01:51 PM
BasicConcepts's Avatar
Technical User
well the 1 belt runs everything and there is a tensioner it sounded like the ps pump, when you got close to that it seemed like it got a little louder id start cheep get a new belt then a tensioner and if thats not the case then id look at the ps b4 anything but im on a crappy laptop with garbage speakers sooo...
Old Mar 10, 2010 | 03:48 PM
if its power steering the noise should change when u turn the wheel. i would look to the tensioner. try squrting a small amout of lubricant on it and see if the noise stops or changes. if so thats the problem part. try not to get it on the other things that need checked.
Old Mar 10, 2010 | 04:46 PM
It's really hard to judge from the video. You have been feeding the chipmunks haven't you?
The squeak sounds familiar to when I've had a noisy A/C clutch. With the engine off, you can try squirting a little oil on the clutch between the inner and outer housing (where it free-wheels when unlocked between the inner hub and outer pulley). If it quiets down, you've found your squeaker.
Old Mar 10, 2010 | 08:19 PM
Well, I will probably have to wait to switch anything out. Saving for motorcycle atm. T_T As long as it isn't actually affecting the camaro I can live with it for awhile. Thanks for all the help thus far.
Old Mar 11, 2010 | 08:26 AM
Have you never heard the old saying
"the squeaky wheel gets the grease" ?
The noise is telling you something, to ignore it would be unwise.
Old Mar 15, 2010 | 01:37 PM
Bump for more solutions. I can't afford to just swap parts out. :3 Does anyone need anymore information about the problem before they can help?
Old Mar 15, 2010 | 05:47 PM
did u try any of the suggestions? if so what did u try and what happened?
94ChevyCamaroV6
Oct 1, 2011 11:44 AM
sparky555
Nov 11, 2010 09:49 PM
CamaroScotty
Oct 26, 2010 08:49 AM
