Voodoo Cams
Old Nov 27, 2009 | 09:15 AM
  #41
Yep! The more it puts a smile on your face, the often you want to enjoy it!
Old Nov 27, 2009 | 03:59 PM
  #42
tbl76camaro's Avatar
So will a Holley 600 fit the intake manifold?
Old Nov 27, 2009 | 05:29 PM
  #43
Depends. Not sure which 600 you have, and which manifold pattern it is. If it's a square bore carb, then you need a square bore Holley.
Old Nov 27, 2009 | 07:31 PM
  #44
Y2K's Avatar
Y2K
There are adapter plates to put a spread bore carb on an even bore intake and vise versa but it's certainly not an optimal set up.
Every Holley 600 I've seen was an even bore,the 650's come in a wide variety some even bore some spread bore some double pumpers with manual
secondaries others single pump with vacuum secondaries.
If you don't know the difference here's a couple pics,the spread bore carb has small primarys and the even bore has all the same size hence "even".
There are different manifolds for the different type carbs.
Typical spread bore.
Typical even bore
Different manifolds
Old Nov 27, 2009 | 10:07 PM
  #45
Here's my carburator. Would it fit?
http://www.jegs.com/i/Holley/510/0-80457S/10002/-1
Old Nov 27, 2009 | 11:08 PM
  #46
Y2K's Avatar
Y2K
Would it fit what?
Old Nov 27, 2009 | 11:21 PM
  #47
Old Nov 28, 2009 | 09:42 AM
  #48
Y2K's Avatar
Y2K
Originally Posted by Y2K
Would it fit what?
Yup.
Old Nov 28, 2009 | 10:22 AM
  #49
If I install the intake^^^, I shouldn't be expecting much power should I? Cause I can't imagine it adding that much power over the stock. I mainly want it because of the looks(mine is black and I don't like it). Then after this I'd build up the bottom end and put in cam, heads, etc...
Old Nov 28, 2009 | 12:23 PM
  #50
You'll probably feel a little increase in power, especially if your present carb is a little tired.
