U joint and pinion yoke issues
Old Sep 24, 2018 | 08:37 PM
4spdz28's Avatar
Default U joint and pinion yoke issues
I’m having problems with my u joints and driveshaft. I have replaced many before but it’s strange on this car because the 8.5 10 bolt pinion yoke has no “pocket” for the u joint caps to sit in. I replaced the rear u joint with a Moog 534 and some new u joint straps and bolts. I torqued them properly and the driveshaft came off the car in 2 blocks! It’s as if the straps don’t clamp the u joints tight enough. Is the pinion yoke just worn out or am I missing something really simple?
Old Sep 24, 2018 | 09:12 PM
The yoke is supposed to have tabs at either end that the u-joint caps fit snugly between. If yours doesn't have the tabs, you need to replace the yoke because either the tabs snapped off or someone "removed" them.
Old Sep 24, 2018 | 09:13 PM
Old Sep 24, 2018 | 11:04 PM
4spdz28's Avatar
I just realized it looks like there should be retaining clips that slide in the u joint cap and go inside the pinion yoke. Mine looks like this. Thanks
Old Sep 25, 2018 | 12:12 AM
Oh, you have that style of yoke! That makes more sense.
Old Sep 25, 2018 | 06:54 PM
Everett#2390's Avatar
Also, you may need a crossover(?) U-joint meaning driveshaft is a 1310 size and since 8.5 yoke, 1350 size.
Larger 1350 has C-clips inside yoke, picture does not show in thread.
ColbyL
53
Jul 27, 2019 11:37 PM
RedSled99
Feb 29, 2012 12:41 PM
1971BB427
Apr 29, 2011 08:12 AM
stox58
Apr 18, 2011 08:46 PM
chrisgray86
Jan 24, 2011 05:21 PM
