Turn signal bulb change
Old Aug 31, 2018 | 10:06 AM
Mark Walker's Avatar
Default Turn signal bulb change
How do I change the rear turn signal bulb on my 78 camaro, the only videos I have found concern replacing the tail light assembly. And they say you have to loosen the bumper and lower it to change the tail light.
Is this also what I need to do to change the bulb?
Old Aug 31, 2018 | 01:50 PM
Zspoiler's Avatar
Thats so wrong I have a 1979 Z-28 RS .The way you change the bulbs on your car. Is to open the trunk. And you will see big plastic wing nuts on the very back. You just turn those to pull your taillight assembly out. Then you just pull the light sockets out .And replace what ever bulbs need to be replaced I would make sure they are clean before you re install them. I have a little trick to make them appear brighter.I disassembled mine and painted the regular silver backing .With chrome silver paint.Then drilled a small hole to drain any moister inside the lense as well.
Old Aug 31, 2018 | 03:54 PM
Thank you for your help. Done in 15 mins.
metalizerman
Jun 5, 2014 05:10 AM
libertyforall1776
Apr 2, 2012 12:47 PM
joeyninetoes
Apr 7, 2008 11:12 AM
sethscamaro01
Jun 11, 2007 11:47 AM
trish_quillen
Mar 13, 2006 11:51 PM
