transmission swap
Old 06-08-2011, 11:59 PM
Ole Blue '74's Avatar
ya the tail shaft will have one.
  #32
Old 06-09-2011, 08:01 AM
Originally Posted by 75stroker383
Maybe a dumb question, but does the tail stock have a gasket on it where it bolts to the transmission? need to know before I'm under the car thinking "**** now i gotta run to the parts store"
Yes, but why would you pull the tail housing? You don't need to pull it to drop the trans.
  #33
Old 06-09-2011, 08:06 AM
Originally Posted by Ole Blue '74
Its just like with my bro's 3rd gen about 7 or 8 months ago we did the plugs on it and what shoulda taken about 45 minutes took us several hours because we couldn't hardly get to the #7 & #8 plugs plus while trying to put plugs in #2 & #4 I dropped the plug trying to thread it into the head and instead of it landing underneath the car in the grass it lands on the crossmember and rolls between the k-member and the oil pan.
Next time do yourself a favor and get a short piece of 1/4"-3/8" rubber hose about 6" long. Slip it over the plug and use it to turn the plug into the head. When it's threaded in, just pull the hose and tighten the plug.
And for those pesky plugs find an old motorcycle spark plug wrench that's stamped steel. Cut it off so it's only got about an inch of the socket, and then weld a little round bar stock to the side. Bend the bar to an angle that works. It will easily slip over in any tight places and run the pug in or out.
Or get a BBC and have easy access to all the plugs!
  #34
Old 06-09-2011, 11:23 AM
75stroker383's Avatar
I need to take the tail shaft off because it needs to go on the new tranny. The one i bought is from a 2wd suburban and has a long tail shaft.
  #35
Old 06-09-2011, 11:41 AM
Ehhhhh...that's not going to work. A shorter tail housing isn't going to change the fact that the output shaft of the trans is still too long.
  #36
Old 06-09-2011, 05:14 PM
You'll have to change the housing and the output shaft together.
  #37
Old 06-09-2011, 05:22 PM
Is that an easy thing to do? I assume its not. And how would I do this? Seeing as i know jack about transmissions.
  #38
Old 06-09-2011, 05:31 PM
You would have to disassemble the entire trans. The output shaft is literally the first part to go in the case, and the last to come out.
  #39
Old 06-09-2011, 05:40 PM
It's easier to shorten the driveline than to change the shaft. Are you sure your present trans is a short shaft?
  #40
Old 06-09-2011, 05:56 PM
carguy68ssrs's Avatar
Looks like you will be rebuilding your trans now. Sell the other trans to offset cost of rebuild.
Quick Reply: transmission swap
