Transmission problem?
Old Oct 24, 2006 | 09:16 PM
scottlarocco's Avatar
Default Transmission problem?
Gas pedal got stuck while driving my 1967 camaro rs v8 327 auto transmission. Now when i start my car up and put it in gear it works for a few seconds? Transmission problem?
Old Oct 24, 2006 | 10:02 PM
shnormo's Avatar
Default RE: Transmission problem?
It could be your kick down cable. Lube up the linkage at the bracket at the transmission. Also lube the throttle body where the throttle cable pully is attatched. Take the intake snorkel off and use some good throttle body cleaner and de-carbon the throttle bore, throttle plate (especially where they meet the bore), and as far down as you can get. Hopefully that will free it up a little. If you are VERY VERY VERY careful, you can apply a couple dabs of oil on the shaft. You can also use graphite, but oil is easier.
Eddie Cotter
Oct 11, 2014 09:43 AM
BoricuaHec01
Oct 30, 2010 01:09 PM
aktham
LS Series Tech
May 5, 2009 01:40 PM
harvick boy
82-92 V6 Tech
May 21, 2007 08:03 PM
SomeCallMeFonzi
Dec 14, 2006 04:41 AM
