TRANS AM 10 BOLT ?
Old 01-26-2008, 01:36 PM
VIPER RED 78's Avatar
Default TRANS AM 10 BOLT ?
i heard 70-81 trans am rearends are2 inches shorter then a camarossomething to do with scca raceing back in the day igot 325 50s to fit my car without rubbing orginally a six banger car was told trans am rears in it now could be a tall tale if any body could answer would be apprecated.
Old 01-27-2008, 09:58 PM
1969 SS's Avatar
Default RE: TRANS AM 10 BOLT ?
I've switched them before with no problems
Old 01-28-2008, 05:39 AM
you didnt answer the question . is a trans am rear shorter then a camaro? i know they interchange duh its in my car now.
Old 01-28-2008, 11:00 AM
1969 SS's Avatar
if it's in your car, I would have figured that you would know if it's shorter or not, duh[sm=icon_stickpoke.gif][sm=usa.gif]
I said what I said because they fit and there was no difference. I've had them in, with and without discs, same rims, same backspacing and same clearances without any problems, so they would be the same
Old 01-28-2008, 11:22 AM
GRIFF's Avatar
I have a ten bolt out of a 792nd gen if you want I could measure from the spring perch to the backing plate.
Old 01-28-2008, 04:47 PM
when you get a chance thanks. the rear was in the car when i bought it .
Old 01-29-2008, 10:38 AM
1969 SS's Avatar
does it still have the rear discs?
olered
11-13-2011 08:52 PM
mikej20
82-92 V6 Tech
11-27-2010 11:04 AM
camaroz803
07-28-2010 10:59 PM
[god]speed
11-08-2009 11:36 AM
gozzy341
11-04-2007 08:52 PM
Quick Reply: TRANS AM 10 BOLT ?
