tranny wont shift
Old Apr 17, 2008 | 05:42 PM
Misfit79's Avatar
Default tranny wont shift
So my tranny shift at 35 rpm...out of first gear, she scream the whole way...I just finsihed installing a new intake and carb and valve covers...and i thought i labeled them correctly, but i cant seem to find the problem...i have plenty of transmission fluid and there is no fluid leaks...so my next guess would be the vaccum leak maybe? i am not sure, if i did install the lines wrong does anyone have a diagram of what right looks like? i have a 79 camaro 305 (yeah i know 305) any help would be appreciated...
Old Apr 17, 2008 | 06:59 PM
thebandit110's Avatar
Default RE: tranny wont shift
you got the vacum modulator hooked up to a good vacum source??? as well as the kick down cable? was it installed properly. that has nothing really to do with the shift at normal operation. but check your vac. line. to the modulator.
Old Apr 17, 2008 | 09:54 PM
RcrX's Avatar
make sure kickdown cable wont get in a bind. bc i couldnt figure out why mine wasnt shifting right after i put on a performer carb (bad choice)
Old Apr 19, 2008 | 09:06 PM
Diablo87's Avatar
sounds like something may be wrong with ur vacuum modulator. its not allowing the trans to upshift
A.J.
Oct 2, 2012 04:05 PM
4g63t
Jun 2, 2011 04:55 PM
bigtim1985
Sep 29, 2010 11:28 PM
78LT350
70-81 Transmission & Differential
May 10, 2010 01:03 AM
ahlers
Sep 21, 2006 01:35 AM
